How recreate this knob?
Message 1 of 11
Hello
i'd like to create a knob with indentation like thins one : https://www.thingiverse.com/thing:3510079
i tried to draw 2 circle with Loft effect but i can't find a way to make indentation...
do you have any idea?
thanks a lot
Replies (10)
Message 2 of 11
TheCADWhisperer
File >Export and then Attach your *.f3d attempt here.
Message 3 of 11
etfrench
One way would be to draw the indentations in each of your loft sketches.
p.s. Draw one indentation in each sketch and use a circular pattern to create the others.
ETFrench
Message 4 of 11
done 🙂
Message 5 of 11
Hi thanks for your answer,
i think it's what i've done but it doesn't work (you can see my exemple in attachment)
ps:d'après ton pseudo es-tu français?!
Message 6 of 11
g-andresen
try this one:
günther
Message 7 of 11
etfrench
You need to add the circles to both loft sketches (top and bottom).
ETFrench
Message 8 of 11
TheCADWhisperer
This can be done without any Loft features.
Two simple Revolve editing and some pattern and filleting.
Message 9 of 11
that's what i made, not acurate but better result thanks!
Message 10 of 11
chrisplyler
For the OP's desired knob example?
You could just draw it once. Extrude it with a taper angle. But only if you like saving time and effort.
Message 11 of 11
etfrench
There are many ways to do this.  I simply showed how the OP could modify his current file to get the desired shape.
ETFrench
