How do you use parts from one design in another design
Hi All
How do I use parts from an assemby/design in another design?
bespenship
Not seeing your data, generally people set up their design so that each part in a Fusion design is a component.  If that's the case, you can right-click on the component in the browser tree and select "Save Copy As" to create an independent part document from that component.
If you have bodies and have not created componenets, you can right-click on the body in the browser tree and either save as STL, or convert to component, followed by doing a "Save Copy As" on the component as described above.
There are also other variables, depending on how you set up your design - if this doesn't answer your question, please share your design or contact me directly (brent DOT espenship AT autodesk DOT com).
Thanks and cheers,
Brent Espenship
Fusion 360 Quality
Macbook Pro retina - MacOS X 10.11.5 (main)
WIndows 7 Notebook
