construction lines
construction lines
construction lines
I can't find the construction line tool either in the tool bar or when selecting with the rift button. Any clues as to where to look? Thanks
NicolasXu
In Fusion 360, we can toggle sketch line between normal and construction status. Select the sketch curve and right click, the command is in the context menu.
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Thanks for that bit. I dont't get the same context menu when i right click  and then open the sketch optio. what I get is other options. See the attached screen shot. Where am i going wrong?
schneik-adsk
Select the line first. that should give you the option you are looking for.
Kevin Schneider
