- Mute
- Permalink
- Report
Hi Newbie here - built a model in design but want to show the distance between points as I rotate a joint so I can reposition where components are attached to get the design right.
I'm putting together is a knitting bag frame - so I have 2 'legs' that rotate about a joint and these will carry the cross supports which I need to position on the legs, so that the horizontal and vertical distances of the cross supports fit the size of the bag they support when the legs are in the open position.
Is this something that can be done in design mode and how would you do it. Have tried to add a sketch with points joined to the components with driven dimensions but that didn't work. Any pointers appreciated,Thanks.
