You statement contradicts itself. You say the curve is about correct but then you say the arrow and the text will remain straight! Are you saying the only thing that will be curved is the round body with the symbol? As it is now, all bodies are wrapped on a curve, their relationship to each other has not been changed except for the mentioned misalignment of the telephone number with the rest of the text.
You now have the process from the model I sent, you can edited it as needed. If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask.
John Hackney, Retired
