How can I implement this model? Give me some ideas, this is an incremental rotation model after an array
pengtishanye
Observer Observer
pengtishanye
Observer
Observer
like this   ,As shown in the figure, how should I implement this model?As shown in the figure, how should I implement this model? Each rectangle is rotated by a certain fixed angle from the previous one1111.png
davebYYPCU
A few ways to do it....
Spiral Pattern - you need an Addin - Script.
Search here for Translate with Rotation, the Addin was updated recently.
If not, Sweep with a Twist,  then
Extrude > Intersect, an appropriate profile/s
Perspective view???  Might have to be a Loft, if not a twisted rectangle base model.
Might help....
etfrench
There are several ways to do this. One is to loft between the ends with guide rails, then use a split body command to remove the negative areas. Note: A single sketch with a rectangular pattern of a line will give you the split paths.  Another is to create a helix in the surface workspace, circular pattern it with 4 instances, make it solid, then split as above.  Yet another would be to use the previous helix to split a rectangular block, then circular pattern that feature.
ETFrench
