How do you constrain the distance between two components such as a table and a chair
mjbmikeb2
mjbmikeb2
So that you can move the table around a room and the chair follows keeping the same relative distance to the table.
jeff_strater
Rigid Joint between the table and chair, with an offset specified:
Jeff Strater
Engineering Director
mjbmikeb2
Is it possible to make the joint constraints always visible like dimensional constraints?
For example, to design a fence around a garden, first I create a fence post component, then I duplicate it several times,  then I add joints to space them apart. As far as I can tell I can only see one of those join constraints at a time. I would like to see all of them at the same time.
TheCADWhisperer
@mjbmikeb2
Is the Design Intent for the fence posts to be in a Pattern?
mjbmikeb2
Not a regular pattern.
laughingcreek
create a sketch. dimension points in the sketch and use those as anchor points for your joints.
