Help needed once again to unwrap an object????
ianhughes7UFVF
Message 1 of 9
ianhughes7UFVF
Hi
If I did this everyday, I would remember how to do a unwrap or unfold of a piece of work.
I have this project that I need to get a flat pattern done so others can cut shapes out.
Except it doesnt seem to work either way:
I carnt convert it to metal nor unfold it.
Any help will be great.
Regards
Ian
Replies (8)
Message 2 of 9
davebYYPCU
To convert, the part must have constant thickness, and be part of a cylinder, or cone.
Lofted shapes are unavailable to Fusion.
Surface, Create > Offset, Set to zero, and save the surface as STL.
Go to Meshmixer and Unwrap the Stl, Export the Flat Pattern and it will Load into Fusion if you need to.
Might help....
Message 3 of 9
ianhughes7UFVF
Hi
I created the offset as you mentioned at 0 and exported the stl.
I dropped it into meshmixer but it wont unwrap for some reason.
I read somewhere that I needed to do a analaysis and repair which I did first but still didnt unwrap?
Am I still doing something wrong or have I missed something?
Regards
Ian
Message 4 of 9
Warmingup1953
Will you laser cut thin steel and simply flex it into the desired shape? I mean can it be conical?
Message 5 of 9
ianhughes7UFVF
Hi
The idea for this is to make a paper template to wrap around a dome on a prop to cut out grooves, so needs to be flat to then be made into a template to print.
Regards
Ian
Message 6 of 9
Warmingup1953
I think your shape is close to Conical but not exact Here I have created a Tooling Cone and and used you Body to Combine Cut:Screenshot 2023-01-19 173218.jpg
Then the lower section of my Cone can be used to create a reveres mask.
Which is Conical...That's as far I have gotten...CAD Whisperer (I think that's right)  has a YouTube Tutorial on the next step that I'll play with tonight.
Message 7 of 9
TheCADWhisperer
Where is the history for this part?
Message 8 of 9
TheCADWhisperer
Message 9 of 9
davebYYPCU
Sorry, I forgot that upgrade, haven’t used it.
@ianhughes7UFVF only time I could not Unwrap, I had to remesh with more triangles, otherwise, ask in Meshmixer forum.
Might help....
