- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to center any individual text character inside a circle. I chose the character to be 20mm in height and it's text style is Bold. The circle is 24mm in diameter but that's not critical.
I can center a text character inside a rectangle except the actual vertical centering is offset because the textbox that a character resides in is taller than the actual character. So, the textbox rectangle is centered but not the actual character.
I hope somebody has a solution to this problem. Autodesk needs to update the character function so that each
character has a center point which would make it easier to center them inside any object.
Thanks in advance for any and all help.
Gary
