How do I wrap sticker text around long axis of cylinder?
gatech.tim2
gatech.tim2
I want to show a sticker I am creating on a cylindrical part in Fusion 360 but can not get it to work.  The letters would run along the long axis of the cylinder (see picture), not wrap around like a ring.
Ideally, I want to create curved text and extrude it into a really thin layer that I can then move into place on top of a component (mesh object).  I tried extruding on that component, but I could not select the face because it just picked up a single face of the component.
So, I created a simple cylinder body and I tried the embossing function, but it won't work.  I can select the text and the face, but there is no option and I can't click OK.  I tried to extrude and cut into the cylinder, but that didn't work.  Even though I could select the text and the body, it would not cut.  Surely there is a way to wrap text around a cylinder.  How would you model a Coke can without that ability?
Any help would be appreciated.
TheCADWhisperer
For a printed sticker I would do as Sheet Metal and Split Face rather than Extrude.
Set appropriate appearances for the faces.
jhackney1972
Embossed Text, either debossed or embossed, should work.  Model attached.
Edit: I read a little closer, you want to move the finished text to a mesh object.  My process will not be correct for that.
John Hackney, Retired
jhackney1972
You can create a surface sleeve from the model I supplied and slide it over a mesh body.  Model is attached.
laughingcreek
as  @jhackney1972 has demonstrated, emboss should work.  can you attach you're .f3d file so we can see why it's not working for you?
etfrench
Here is a cylinder thin extruded to .01".  The text was debossed .005".  After converting it to a mesh, it can be combined with another mesh.
ETFrench
gatech.tim2
Thanks for the model. It verifies that I was doing everything correctly.  The emboss seems to work in this sample file, but if I change the font to the one I need, it no longer works.  So there may be an issue with Trajan 3 font.
