How do I use a "projected to surface" shape for a PressPull command?
rbtyod
rbtyod
I have projected a sketch shape onto the surface(s) of a box.
I would like to use the projected shape to do a press-pull but cannot select the enclosed area.
I have tried projecting to both a single surface and across one box edge. Neither works.
The projected shape has purple lines.
...Bob
HughesTooling
Are the profiles closed, can you attach an example f3d and or some screen grabs.
Mark
Mark Hughes
Owner, Hughes Tooling
rbtyod
Mark, thanks for the reply.
After a good bit of further fiddling around, I found that, apparently, the shapes must be closed and the projections must be completely contained within a single target body's face.
Splines, circles and rectangles all seem to work.
...Bob
