Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How do I turn of highlighting when moving an object?
1 REPLY 1
waltersandmeyerNYVLH
112 Views, 1 Reply
Hi there,
Sorry if this has been asked before, but I don't see a solution to this, and am not sure if there is one.
I want to move a part point-to-point, but when the part is selected, it totally obscures the point I want to move it to.  The visibility of the component that's blocking the point is already turned off, but it still highlights and obscures the view.
I know I can move the part far away, clear the view, and then move it to the point I want to select, but I encounter this issue a lot and would love a way to just turn off, or turn down the opacity of the highlighting.  Is there a setting for this that I haven't found?
1 REPLY 1
Please share the model. Export it as as .f3d file and attach it to a post.
In general, unless you are in direct modeling mode I would stay away from the move command!
Technology Administrators
