How do I resize an object without everything just messing up?
jgar63110
jgar63110
Community Visitor
Community Visitor
I'm working on a project but the problem is every time i try to use the sketch dimension tool it always messes up the shape or just adds a straight line ruining the object can someone help me please here's the dimensions I'm trying to do: https://www.dimensions.com/element/xbox-one-controller Screenshot 2025-03-03 081714.png
TheCADWhisperer
@jgar63110
Having said that, this is not a beginner project - you should master sketching before tackling a project like this.
etfrench
Easy way is to download a model of the controller from GrabCad😀
ETFrench
johnsonshiue
Hi! I guess the sketch consists of splines converted from an image. These curves may not be parametrically driven in the original design. Or the curves are silhouettes of a rounded shape. To resize such shape, you could create a planar Patch surface of the profile. The use Scale command to resize the Patch surface uniformly or non-uniformly.
Many thanks!
Software Test Engineer
