How do I make this type of joint?
Message 1 of 14
I'm a noobie and cannot figure out how to make this kind of joint.  How would I go about this?
Replies (13)
Message 2 of 14
g-andresen
More detailed information is required for a response.
For this it is necessary to share* the file and specify which components should be connected and how.
günther
* File > export > save as f3d on local drive > attach to next post
Message 3 of 14
mango.freund
Hi @Anonymous  to me it looks like the "between two surfaces" is the best joint.
greetings mango
Message 4 of 14
don't really have a file.  the photo shows two "rails" on the right pic which make a "raised slot".  The left pic shows a separate piece which will fit into the "raised slot" when the box is manually assembled(outside of fusion 360).
Message 5 of 14
It should look like this.  I can make it by creating 6 different extrusions, but was hoping there was an easier way
Message 6 of 14
g-andresen
try sweep > screencast
günther
Message 7 of 14
mango.freund
Hi @Anonymous you're right - it's easier when we know what is needed.
only 2 extrusions are needed for this part. OR you are harry potter.😀                     greetings mango
Message 8 of 14
jeff_strater
@Anonymous - I think you confused us with the term "joint".  In Fusion, Joint is a way to connect two components.  If you are talking about modeling this geometry, here is another way to do it, using an extrude and a sweep.  Plenty of other ways to get there, though.  Your way is probably fine.
Jeff Strater
Engineering Director
Message 9 of 14
Do you 2 per side? If not how do I do it with just 2?
Message 10 of 14
mango.freund
hi @Anonymous take a look ---timeline / skizze
Message 11 of 14
jeff_strater
not quite sure what the question is, but several of the solutions have attached models - open them and take a look at the features.  In my case, for the "grooves" part, I did this with one sweep, with two profiles:
And using the edges as the path:
Jeff Strater
Message 12 of 14
g-andresen
1. watch the screencast # 6
2. follow the timeline
günther
Message 13 of 14
Thanks, that gets me there
Message 14 of 14
Thanks for all the suggestions.  They are all helpful to a noob like me!
