How do I make the T-spline surfaces uniform in Fusion?
Message 1 of 22
I have successfully converted some medical models to T-splines using Autodesk remake and inventor. But please, how can I make these T-splines uniform? The T-splines generated are of various sizes and they have remained on the body even after converting to a water tight model for analysis in ABAQUS.
I will like to make the T-splines of uniform size and have more control over each region they occupy. Please how can I do this?
Gaby
Replies (21)
Message 2 of 22
PhilProcarioJr
@Anonymous
It's hard to help without seeing your files and what exactly you are trying to do. A screencast goes a long ways to help us understand your problem.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 22
Here is a screenshot
Message 4 of 22
PhilProcarioJr
@Anonymous
Is this what your after?
Phil Procario Jr.
Message 5 of 22
cekuhnen
@Anonymous
That is also normal. TS decides on its own how the surface will be broken up into BREPS.
Phill showed you how you can manually refine that however with such a complex model you
have you will remain having a crazy BREP patch layout. Why is that an issue for you?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 6 of 22
@Anonymous
Like Both @PhilProcarioJr and @cekuhnen mentioned, T-splines decides how to patch such geometry.
The only other way i can think of is doing the patching manually in T-splines. See here as an example: https://www.youtube.com/watch?v=SdMxlNhKBmg
Or by using another reverse engineering package and also do it manually.
@cekuhnen I'm assuming he needs lesser or uniform faces to help with his FEA.
Message 7 of 22
Thank you very much for the comments.
I will explore the different suggestions
Message 8 of 22
PhilProcarioJr
@Anonymous
I am truly hoping no one ever uses the method in that video....Smiley Wink
Phil Procario Jr.
Message 9 of 22
@PhilProcarioJr hahah
I hear ya, I just hoped it would clarify the point of manually patching.
@Anonymous
There's an old video about T-splines in Fusion where it basically shows creating faces/patches onto a geometry directly, however I can't find it.
I'll do a screencast when i'm at my desk.
Message 10 of 22
PhilProcarioJr
@Anonymous
"There's an old video about T-splines in Fusion where it basically shows creating faces/patches onto a geometry directly,"
I would avoid this method also as currently in Fusion there is no way to deal with surface tension and the results are not accurate at all.
If you don't care about accuracy then this method is ok, but I would still avoid it....
The best way to deal with this problem is using a retopology app like Topogun on the scan mesh... then using the relax brush... then bringing that quad mesh into Fusion as a T-Spline and doing a conversion with keep selected edges. You can maintain accuracy and control over the uniformity of the model face flow and edges...
Phil Procario Jr.
Message 11 of 22
@PhilProcarioJr I was under the impression that "make uniform" command resolves surface tension, no?
And just for clarity, by surface tension you mean the "invisible" edge weights? as in opposite sides equaling 1 as in attached pic?
Message 12 of 22
PhilProcarioJr
@Anonymous
"I was under the impression that "make uniform" command resolves surface tension, no?"
No, at best it will smooth out some kinks in the surface, but honestly it's junk...
Surface tension is the amount of edgeloops and their placement required to maintain the shape accurately, if you don't have enough the surface approximation will not match the scan model to many and you get kinks in the surface. I will try to put together more info when I have time. Surface Tension is next to impossible to handle manually thus the reason I mentioned the relax brush in Topogun as it calculates this for you and adjusts the edgeloops in the mesh for you.
I have yet to see a good video tutorial on T-Splines for use accurately as a CAD model. It can definitely be done but not the way the videos are showing.
Phil Procario Jr.
Message 13 of 22
Thanks @PhilProcarioJr learned something new today.
However, I think @Anonymous is more concerned with his/her FEA analysis more than perfect topology so reduction in faces is I think the real issue here.
Message 14 of 22
Exactly...im concerned about the FEA analysis
Message 15 of 22
PhilProcarioJr
@Anonymous @Anonymous
"Exactly...im concerned about the FEA analysis"
This is exactly my point...the less accurate the model is to the real thing the less accurate your FEA analysis data will be.....
In the end you want a model that represents as accurate of a model as possible while still allowing the simulation software to be able to mesh it.
Phil Procario Jr.
Message 16 of 22
Not to beat a dead horse Smiley Happy
@PhilProcarioJr depends on the analysis really. And on top of that, surface tension or imperfect (not so matching) topography wouldn't matter.
Normal practice in FEA is to "simplify" the model by removing fillets, holes etc etc. So a fem 1/10th of millimeters in non-perfect topology shouldn't matter much.
Message 17 of 22
PhilProcarioJr
@Anonymous
When I run sims on models I don't simplify them and the simulation software doesn't (at least for me) so you guys must do things differently then I do which is fine. Carry on. Smiley Wink
Phil Procario Jr.
Message 18 of 22
TrippyLighting
What uniform does is it basically re-aligns the T-Spline handles. It does not always work, so a standard way to handle such situations is to actually export the control mesh from Fusion 360 and then re-import it as in that case Fusion 360 has to re-calculate the T-Spline handles from scratch.
Message 19 of 22
Thank you very much. But what format do I use to export it to retain this new surfaces? I think fusion can only import stl and obj files. Or am I wrong?
Message 20 of 22
TrippyLighting
.obj export is in form of quad meshes.
You need to make sure that you have disabled "Triangulate meshes" in the MESH preferences, otherwise Fusion 360 triangulates meshes on import.
