How do I make a coiled ellipse?
Message 1 of 18
I would like to make a simple ellipse coil. One 'rotation"  so from the front view the ellipse looks normal, but from the top view it is extended like a coil spring.  The coil tool will not make an ellipse, what do I do?
Replies (17)
Message 2 of 18
I_Forge_KC
Create a coil with a triangular section, then use one the edges to do a sweep of your ellipse.
K. Cornett
Generative Design Consultant / Trainer
Message 3 of 18
 That gives me a circular coil of an ellipse section, and works well doing that, thanks! see the attached.  That is not what I am trying to accomplish.
I need a coiled ellipse with a circular section.  So instead of a circular coil in front view, it is an ellipse.
Message 4 of 18
Ok, I got what I wanted, i made the coil the height and length I wanted and then non uniform scaked it to an ellipse.  Thanks, I would not of figured it out with out your input!ellipse coil.JPG
Message 5 of 18
I_Forge_KC
Yep, was literally just posting this
K. Cornett
Message 6 of 18
Claus_J
There is an add-on that create a helix spline, search for it, you can then scale the spline non-uniform and finally tube it. Actually I wonder why the developers did not make a helix tool that creates a sketch element.
Message 7 of 18
How do you achieve this without deforming the cross sectional shape?
Message 8 of 18
tormy.vancool
Well it's not clear at all to me.
Even by choosing triangular profile, the coil si circular and not elliptical.
I need to have a circular section of the wire, and the section of the coil must be elliptical. I really can't figure out how to get it properly done.
Message 9 of 18
TheCADWhisperer
@tormy.vancool
Message 10 of 18
davebYYPCU
Surface Sweep a line for one turn (360 - twist angle)
Extrude the ellipse (> Intersect) to trim the coil to plan form ellipse.
Add Pipe to elliptical edge of the surface.
Might help.....
Message 11 of 18
tormy.vancool
I have only endeavors since I'm not able to finish it ... I need just to design an coil with elliptical section instead of the standard circular one
Message 12 of 18
tormy.vancool
Sorry I'm not able to fully follow what you described since I'm a noob ... many things are for you obvious, aren't for me 😕 Can you please repeat with step-by-step so I can execute and get the result done and also understanding what I'm doing?
Message 13 of 18
TheCADWhisperer
Attach your attempt here.
Message 14 of 18
tormy.vancool
Ah Ok I didn't explain myself good. Me bad.
That section (the section of the wire) should be circular. And this is as default since I can chose: circular/square/triangular.
the coil section should be elliptical instead. I mean: once the coil is finished and I watch it from the top, I have not to see a circle but an ellipse.
Message 15 of 18
TheCADWhisperer
@tormy.vancool
Can you File>Export your *.f3d attempt file to your local drive and then Attach it here to a Reply?
BTW - It probably would have been better to start a new thread with a link back to this old thread as reference.
The software changes and techniques we would have used 5 years ago aren't necessarily the same techniques we would use today.
Message 16 of 18
tormy.vancool
Please in attachment the file ... as you will notice, the section of the coil must be oval. not the one of the wire.
Message 17 of 18
HughesTooling
@tormy.vancool I did answer to your other post but here's the file using your specifications. It shouldn't be too distorted as the pitch is shallower then in my other try.
Mark Hughes
Owner, Hughes Tooling
Message 18 of 18
davebYYPCU
Step 1, Draw a vertical centre line (Path - black) Draw a horizontal line, (Profile - blue) on Front plane.
Sizes that suit you.
Step 2 Surface > Create > Sweep the blue line around / up the black line.  Circular for now.
step 3 Hide your work.  New Sketch draw your ellipse on base plane.
Step 4 Unhide the Sweep body, Solid > Extrude the Ellipse set the operations to Intersect.
(will cut the outside area of the sweep body away.)  Set to Cut, will cut the inside away, won't matter for next steps.
Intersected - looks like this.
Step 5 Add the Solid > Create > Pipe, > circular > size to suit. Select the edge of the elliptical coil.
Hide / Remove the surface body
Might help.....
