How do I edit the size of the revision marker
benjamintoews
Message 1 of 8
benjamintoews
I seem to be missing something. I haven't used the revision table much but when I place a revision marker, it is so large it interferes with too much of the drawing. Is there a way to resize it? I have attached a pdf.
Replies (7)
Message 2 of 8
ClintBrown3D
Hi @benjamintoews
That looks like a bug!
Please share a downloadable link to your drawing, so that I can ask the team to investigate this, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 3 of 8
liang_chen
Thanks for the feedback and dataset.
I only reproduce the issue in the shared dataset, and it has been tracked as internal ticket (FDWG-18521). I do not find any specific setting leads to the large size. Does this issue happen in every drawing file? Pls create another drawing and check if issue is still there.
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
Message 4 of 8
ibahru
Observer
Observer
I also have the same problem. How to rescale the triangle of the revision maker.
Message 5 of 8
liang_chen
The size of triangle can't be rescaled manually. It is an unexpected behavior that revision maker is large in ASME standard drawing. Usually, this issue happens when change the text settings in revision maker.  We are working on a fixing.
Thanks for the feedback and patience.
Fred Chen
SQA Engineer
Autodesk, Inc.
Message 6 of 8
Dylan_Rawlinson
I have had a similar issue to benjamintoews, although much less dramatic.
Being able to manually override the scale of these markers would be a beneficial update.
Message 7 of 8
evernoe_caprangcaNPSBG
These don't intersect when drawing was released last year. but opening it today and it appears like this. how to fix?
Message 8 of 8
Gus-Collier
Also here to bring up this issue. The markers can get comically large if you have a revision name longer than 1 character.
