How do I create longitudinal grooves wrapped around a cylinder?
Message 1 of 10
I'm new to Fusion and having trouble figuring this one out.
I need to add shallow V grooving longitudinally completely around a cylinder. A gentle nudge would be greatly appreciated.
Thanks!
Replies (9)
Message 2 of 10
HughesTooling
 OK reread what you're after extrude cut a V then use circular array.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
JamieGilchrist
create two sketches
1 is the path around the cylinder
2 is the trangle for the "V" goove
Sweep the triangle
or
skip the 1st sketch and use the revolve command; the triangle as your profile and the axis of the cylinder (may need to create a construction axis for this if the cylinder is off the main origin location)
let me know if this gets you there or if you need a little more nudging.
EDIT:  rereading, Marks solution is the right one for longitude groove, mine is a groove lattitudinal to the cylinder.
hope this helps
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Message 4 of 10
HughesTooling
Ever feel like this. A few pictures would make all the difference!
Mark Hughes
Message 5 of 10
Sorry about that.
Mark is on the right track with the first post, but I can't figure out how to incorporate that in my current model.
The area highlighted in blue needs to have longitudinal v grooves along the long axis that wrap radially around just like your first post shows. It's grooved for gripping.
Message 6 of 10
think transmission spline but on a much smaller scale 🙂
Message 7 of 10
JamieGilchrist
Like this?  I'll post the Fusion model so you can see how I built this.
 Edit:  attached my model that essentially follows Marks workflow.  Hope this helps.
hope this helps,
Jamie Gilchrist
Message 8 of 10
HughesTooling
What I'd do is create a plane where you want the splines to start.
Draw the profile of the grove on that plane. Then extrude cut
Then make a cicular array, for pattern type select Faeture and select the extrusion from the time line. For axis select one of the other round parts set the number of copies then OK.
Example file attached.
Mark Hughes
Message 9 of 10
Thank you both!  That's exactly what I needed.
Message 10 of 10
HughesTooling
Just another tip on Circlar array, you can select more than one feature if you need to. You can make your splines look more realistic if you plend the end out as if thay where milled like this.
File attached.
Mark Hughes
