How do I add a human for scale
devonY8YC6
Message 1 of 11
devonY8YC6
I am working on a sculpture proposal and am stuck at the point of adding a human figure for scale next to the object. I assume this is something that should be readily available like it is in sketchup, however I find myself unable to find an answer and my last resort is here for answers. Thanks for any help.
Accepted solutions (3)
Replies (10)
Message 2 of 11
Drewpan
If you don't want to create your own human model then most people will go to any
of the modelling sites and download a model of what they want from there.
GrabCad, TurboSquid, Thingyverse, free3d.com, there are a few out there, just google
them like I did.
There may even be a free human download in the AutoDesk user models section.
Try this one.
https://www.autodesk.com/community/gallery/project/32457/t-spline-human
Cheers
Andrew
Message 3 of 11
devonY8YC6
Thank you, I already have downloaded some free human obj files and am struggling with getting them to scale at the moment. I just find it really hard to believe that there isn't a preset in Fusion for adding a human model for scale. This seems like a major oversight and many hoops that need to be jumped through in order to add a human for perspective in an architectural drawing.
Message 4 of 11
Warmingup1953
I use this guy/gal/it. Comes with mainly correct joints.humanoid.PNG
...found online from a free resource but I regret I no longer have a record of where for attribution.
Message 5 of 11
devonY8YC6
Thank you.
I have used this figure and a woman who was available for free also.
https://www.cgtrader.com/free-3d-models/character/man/ivan-1304
Message 6 of 11
TheCADWhisperer
@devonY8YC6
That is really the root issue that you should conquer, you should master scaling geometry to virtually any size that you need.
Ask questions about that topic.
Message 7 of 11
devonY8YC6
I have been able to get them to scale, it's a simple math problem based off how they imported. Not so much as a struggle as I feel it is just so many steps for something that is usually so simple in other programs, like Sketchup for example. Especially since this figure feature is very common in drawing proposals. I wanted to make sure I wasn't overlooking a simple add on feature in Fusion, but it seems like this multiple step process is what needs to happen.
Message 8 of 11
TheCADWhisperer
@devonY8YC6
Can you Attach an example file (original before import), I suspect it is simply a Units issue.
Message 9 of 11
asoulby
Have you resolved your problem, as I cannot figure the scaling as well, what has work for you?
Cheers Andrew
Message 10 of 11
a24_ratuki
Community Visitor
Community Visitor
Is there anyway to make the mannequin seated ?
Message 11 of 11
Warmingup1953
Yes indeed! The Joints allow you to pose the mannequin:AP1GczOBQOFeSRkEUzoIQGzsM1bqicATpks9FZnq5L4PwtbGjmOxija5PL6Cgg=w2575-h1932-s-no-gm.jpg
You simply deep select and invoke Drive Joints Command:
I have circled the "Flags" for the wrist but I am driving the Head Joint here
