How curve edge and how fit to surface
jonniepickering
Message 1 of 27
jonniepickering
Hi folks,
A couple of questions please.
I have created this sculpture of a spoiler extension for a car. I have created one half so it can be mirrored.
I want to please create curved edges please, the back edge should be fully curved and the front edges that attach to the existing wing should just curve down to the surface (90 deg)
Two pictures below and full export attached.
Also one other question
How do I cut away the unwanted material from the inside of the model so it fits the rear of the existing wing.
Many thanks
Replies (26)
Message 21 of 27
TrippyLighting
Cool! Here's the 2nd part.
Message 22 of 27
jonniepickering
Aha, I see, so once you have completed the t-spline sculpture, you then have to convert it to a BREP and then it's a simple split face exercise.
One question. Is it possible to split the face against the original scan (.stl) face, or will I always have to create a BREP of the scan face first to split against? Just thinking of future projects and the process I will always have to follow.
Will it always be
1) Recreate face as BREP
2) Create new t-spline sculpture
3) Convert sculpture to BREP
4) Split face
Many thanks for this. This is far more than I was expecting!
Legend. Many apologies for how things started..
Message 23 of 27
TrippyLighting
A T-Spline is really just an intermediary form between a quad mesh and a Brep/NURBS surface.
That is the reason you'll have to convert it. When the T-spline encloses a volume watertight, it converts into a BRep containing NURBS surfaces (in this case).
If the T-spline is open it will convert into an open (NURBS)surface body.
Then I use the split body command utilizing the surface created from the scanned data.
You can't directly use the scan data, as that is a triangulated mesh. This has to be reversed engineered into a surface before you can do much with it in Fusion 360.
Message 24 of 27
jonniepickering
OK, that's awesome, thanks!
I guess I'll mark this one as resolved.
Thanks again so much for the help!
Message 25 of 27
chrisplyler
Told ya. @TrippyLighting  is a badass. Now if we could just get him to wear deodorant.
Message 26 of 27
jonniepickering
One question Peter, how do you get the colour of the final model to change to that greenish finish?
Message 27 of 27
TrippyLighting
Sorry for the very late reply. I stopped getting any Forum notifications 😕
I use color cycling:
