Thanks for helping. I'm not sure what points I missed from Trippy though, care to explain? I watched the video clip 3 times and noticed that the way I built my sweep was the same as his except for the points I mentioned. My point being that my spline (before being sweeped) did NOT intersect itself and his did. I was asking if this is why his worked – which does not seem to be the case.
To answer your other point about you advising on intersections (from the other topic) – yes you have advised, and I understood what you said. I think you think I am asking the same question here, but I am not. This thread was not about how to handle intersections (which you helped with in the other topic), it was asking how I might achieve the desired result without intersecting (because I can’t get the thing to work). Naturally, Trippy wasn’t aware I had already discussed intersection issues in another thread, so he started to explain using similar points as you did. So, I did take on board what you said 😊, I was just asking a different question.
Bear in mind I am an absolute Fusion noob and new to CAD also, so there is huge learning curve for me, and I’ll likely ask some dumb questions!
On to your point, you did say I can use Isocurves and analysis tools, but nothing more beyond that. I turned on the curvature comb, and Isocurves but don’t understand how to read and analysis it. In your second example, what is the significance of the distance you have between the two points at either end of the spline? I feel you have highlighted this for a reason.
Also, thanks for the file, I just looked at it and have some q’s:
What is it in your design that allowed it to intersect but fails on mine? Is it the restraints you added to sketch, or is that you split the circle into two halves? Even looking at what you did and stepping through the timeline does not intuitively make me see how it worked; it would help a lot if you could explain why you did it the way you did to make it work. Your spline doesn’t look that different to mine, so I don’t understand why yours worked and mine did not.
Sorry for the long post, just trying to understand everything, please answer all my q’s.
Thanks again!
@graham_S_allen -this post has been edited due to Community Rules & Etiquette violation
