Folks,
I've got an PCBA assembly imported from a STEP export out of Altium. The assembly is actually two boards connected by breakaway headers. To make my Fusion assembly, I need to make singular instances of the left and right (boxed in dashed red) i.e. I need to make instances where I eliminate the PCB and electronics components on side I am not keeping.
To accomplish this, I'm selecting one set of bodies (i.e. choose a side and select) and would like to remove all the selected bodies in one shot, but the context menu on right click does not have "remove" as an option if I select multiple bodies. Delete isn't an option as it will delete all instances of selected components, including those on the side of the PCB I am keeping.
Is there a workaround someone knows for this? Or should I just select and remove one by one . . .
Art
PS: Using a sketch that covers one side of the board, and then selecting the bodies I want to remove in the "Bodies to Cut" pane acts the same as delete - i.e. all instances disappear even though the cut is only on one side of the board. 😞
