How can I make guide rails between two sketches?
Hi I am buliding a assembly. The components is built where its supposed to be in the assembly. Now I am trying to make a turbine blade. I am using the loft function and I want to use guide rails. My problem is that I can't get the rails connected to the sketches. I made the rails in the XZ plane so the rail is not being made at the same place in the room as the other two sketches.
How can I connect the rails between the two sketches?Screen Shot 2018-06-05 at 20.01.06.png
jeff_strater
@Anonymous:  Here is a (very wordy, I apologize) discussion about creating rails for lofts:  introduction-to-loft-using-rail-curves-in-fusion
Hopefully this helps in your case.
Jeff Strater
Engineering Director
