How can I make a hinge?
bearman305
Message 1 of 16
bearman305
I am looking for someone who might be able to help me concerning making a hinge close.  The snip of a base, with hinge and lid, I would like to make it appear to open and close.  I have tried to use the "joint" features, but I don't get the result I am looking for.  Thanks for any help you may offer.
Replies (15)
Message 2 of 16
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach to post.
günther
Message 3 of 16
Warmingup1953
I assume you'll be 3D printing the reduced cross-section element (the "Hinge") in TPU or similar and you need to simply illustrate this? Still images or video?
Message 4 of 16
bearman305
Thanks for responding - Waringup1953
Still images would work, however, I think making it animated via video
would be cooler.
Message 5 of 16
bearman305
Thanks for responding g-andresen ... see attached file
thanks for your help - Wade
Message 6 of 16
g-andresen
no f3d file attached
günther
Message 7 of 16
bearman305
I'll try it again ... thanks
Attached is a snip of what should be attached.
[image: Capture.PNG]
Message 8 of 16
g-andresen
still no f3d
Follow my description in #2
günther
Message 9 of 16
bearman305
Gunther,
Any idea why the attachment appears to be loaded and sent, yet you do not
receive it? Is there something I am doing wrong? I wouldn't say I'm tech
savy so I'm not sure what to do.
Thanks for your willingness to help,
Wade
Message 10 of 16
jhackney1972
Could be you are trying to attach your model using an email reply.  You MUST return to your Forum post and use the Attachment section of a reply post.
John Hackney, Retired
Message 11 of 16
g-andresen
Try this
günther
removed „marked solution“
Message 12 of 16
bearman305
ok ... I'll give that a shot...thanks
Message 13 of 16
bearman305
just added drawing back to original post
Message 14 of 16
bearman305
nice job ... how did you create that?
Message 15 of 16
jhackney1972
My post is not the solution to your question, it is simply telling you the proper method of attaching your model to a Forum post.  I removed it as a marked solution.  When you get a response that actually solves your issue, then "Accept Solution" on it.
Message 16 of 16
bearman305
Thanks for the illustration.  Can you explain to me how you were able to accomplish the movement of the hinge?  Thanks
