Convert to sheet meal
saitoib
saitoib
Hi all
Is it possible to convert a batch of solid models like the one attached to sheet metal?
Thank you.
Saitoib
TheCADWhisperer
@saitoib
1. No Fusion *.f3d file attached (just a pretty picture).
2. No bends in the part...
3. ...and therefore the thickness is not uniform.
https://www.youtube.com/watch?v=BAa6J0Pigp0&list=PLp5izJt_zvN29W2cEFHAK949eImc9xFOT&index=1
Warmingup1953
In the case of your example, rather than convert which will need you to finess the body so that it complies with the Sheetmetal rules it may well be prudent and perhaps easier to start again in the Sheetmetal environment.... But I assume your Batch has more complex examples? Can you share your Fusion file(s)?
saitoib
When a solid model is shelled, a vessel of uniform thickness is created.
Can I split this with a surface and convert the individual parts to sheet metal? 
Saitoib
Warmingup1953
Your sharp corners among other things are the issue....The thickness on the sharp corner is 1.41X the uniform. I think the CAD whisperer video albeit with the older UI will be well and truly worth watching
laughingcreek
@saitoib wrote:...When a solid model is shelled, a vessel of uniform thickness is created.
not directly.  there will have to be some corrections made (such as adding fillets, etc.).   It will be a manual process.
attach a sample model and someone can show you.
TheCADWhisperer
No. Not uniform thickness from Shell.
Yes.
