How can I make a frame with a profile
Hi All
I want to create a frame that has a profile, like a picture frame with 90 degree corers.  I know how to make a round one but how would you make a square one?
3DMan
HughesTooling
An easy way, start a sketch from the sketch menu pick centre rectangle and create 2 rectangles using the same centre.
Then exit the sketch and extrude.
It this is not what you're after attach same screen gabs of what you need.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark
I hand figured that bit out, but I want the frame sides to have a profile like a picture frame.
for example cut youre frame in half and look at the exposed end it will be square I want it to have a shape like the cross section of a picture frame , an I bar or even a round bar.
3DMan
HughesTooling
You might get what you want using Sweep draw 2 sketches, one a rectangle to use as a path and one a cross section.
Mark
Mark Hughes
Thanks Mark
That looks like the answer, will try it out later.
3DMan
