How do you add an internal radius to a sketch
H iAll
How do you add an internal radius to a sketch where the angle is less than or greater than 90 degrees I have tried using a three point circle with limited success and a lot of patience there must be a better/easier way.
Thanks for you help#
3DMan
HughesTooling
You could use fillet.
Or if you want a full circle use 2 tangent Circle.
Have you gone through the basic training and help. Try this http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-B5D5FE2F-7C30-4A65-9B90-4312B726C66E
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark
3DMan
