How can I export 3d curves from fusion to a step file
4 REPLIES 4
schader
234 Views, 4 Replies
We use fusion many times to translate catia parts to step files. However, many of these parts have 3d curves in them for things like mating surface definitions, etc. Fusion seems to only export the solid data. Is there some setting anywhere to make it output the 3d curves into the step file, or any other way to get those 3d curves exported?
4 REPLIES 4
TrippyLighting
in reply to: schader
Fusion 360 can import and export solid bodies, analytical and NURBS surfaces. It does not import or export wireframe geometry.
kandennti
TrippyLighting
in reply to: kandennti
Very, very nice!
schader
Very nice, almost what I need, except that it doesn't support catia files!
Technology Administrators
