- Mute
- Permalink
- Report
I cannot get this loft to come out right. Hopefully it is clear from the screenshot what I want to achieve. I want to loft between these two curved surfaces. I've made three sketches for my attempts (Rails1, 2 and 3). One of them is a top view (Rails3), one a side view and one an attempt with 3D geometry projection from the corners that excludes the top view. They should give a good visualisation of how this loft should work. It should be a curved seamless transition between the two profiles, with no hard angles. File attached.
Thanks!
