How can I build this in Fusion?
Good day.
I'm pursuing the design of a Zome structure in Fusion 360. It's a very easy design to draw in sketchup, but I'm having some challenges when trying to do it in fusion. I'm linking to a youtube video that shows how I do it in Sketchup. My suspicion is that this is quite straight forward.
https://www.youtube.com/watch?v=wLwqUjXph2s&t=628s
Thanks for your time!
etfrench
  1. Create a Plane at Angle for one of the top diamonds.
  2. Create a sketch on the plane.
  3. Draw the diamond.
  4. Extrude the diamond.
  5. Use a circular pattern to complete the top row.
  6. Create a Plane Through Three Points (or Plane Through Two Edges) using the bottom of one of the diamonds.
  7. Repeat steps 2 through 6.
  8. Copy the top half and position it using a joint.
ETFrench
Thank you!
