How can a Sketch Offset be made to update as expected when a Rectangular Pattern is updated?
pbmallinson
pbmallinson
Hi, I’d be grateful if anyone could help me figure out how to achieve this expected behavior.
Issue: Component-C Sketch1 Offset perimeter does not update as expected when the Rectangular Pattern of Component-A (R-Pattern1) is updated.
Expected Behavior: Altering the Quantity and or Suppression values in the Component-A Rectangular Pattern should cause the Component-C Sketch1 Offset perimeter to reflect the alterations.
Steps to reproduce issue:
  • Open Question-OffsetSupressedRectangularPatternChange v9 (file attached)
  • Observe Component-C Sketch1 is correctly offset from the perimeter of Component-B Body1
  • Click Component-A R-Pattern1in the History and adjust the Quantity/Suppression as required
  • Review and resolve any errors in the Component-B Combine1 step ensuring the target body is not changed and that all the required bodes are selected
  • ISSUE: Observe Component-C Sketch1 is NOT correctly offset from the perimeter of the updated Component-B Body1
The design has three elements which are currently implemented as distinct components:
  • Component-A: A hexagonal tile arranged with a suppressed rectangular pattern (R-Pattern1) to create a number of bodies.
  • Component-B: New Component created by combining the bodies of Component-A
  • Component-C: Sketch derived from the perimeter of the single body in Component-B
Example file and outline of creation process: (file attached)
Create New Component: Component-A
  • New Sketch
  • Define geometry
  • Extrude
  • Save
  • Suppressed Rectangular Pattern
  • Save
  • Combine Component-A bodies to New Component
Rename New Component to Component-B
  • Save
Create New Component: Component-C
  • New Sketch
  • Project Component-B Body1
  • Save
  • Offset projection perimeter
  • Finnish Sketch
  • Save
g-andresen
the file has no download permission.  > personal license?
Please share it this way;
File > export > save as f3d on local drive  > attach it to the post
günther
pbmallinson
Thanks @g-andresen, yep I have a personal license, file now attached to the original post. Thanks forthe help
