Hook
Hook
GeoffKornfeld
Message 1 of 11
Hook
GeoffKornfeld
Hi everyone,
I am continuing to learn fusion by trying to create models of drawings that are in my 40-year-old drafting textbook. I'm having some trouble with this hook. I have recreated the drawing, but I'm not sure how to make it into a solid. I know the loft or sweep functions should do the trick, but I'm not sure how to make them use the lines I have created. I also don't know why my ellipse fragment (bottom right) turns from black to blue after I trim it down from a full ellipse.
Thanks!
Replies (10)
Message 2 of 11
davebYYPCU
No such thing as an approximate ellipse.
2 point spline and Tangent connections should work.
Sweep major portion with the circle profile.
Create (Revolve) a partial sphere at the tip,
Loft from the Sweep to the modified Sphere, using Tangent conditions in the Loft.
Might help...
Message 3 of 11
TrippyLighting
@GeoffKornfeld wrote:
.. I also don't know why my ellipse fragment (bottom right) turns from black to blue after I trim it down from a full ellipse...
The reason is the halfquarter-baked implementation of the ellipse.
Message 4 of 11
wersy
You can make your hook in a similar way.
Sorry, I forgot to activate the timeline.
Message 5 of 11
TheCADWhisperer
@GeoffKornfeld
Are all of your sketches fully defined (no blue curves or white points)?
(I had my students model this Hook for 25 years.)
I could have used Sweep for all of the circular cross section as suggested by @davebYYPCU , but using Loft give you more options on the shape of the cross-section as illustrated by @wersy .
I suggest you try both ways. (Replace my Revolves.)
Message 6 of 11
GeoffKornfeld
I seem to have figured out how to do everything -except make that ellipse turn black.
Here is a link to an export of the file.
Message 7 of 11
TheCADWhisperer
@GeoffKornfeld
Message 8 of 11
GeoffKornfeld
Ah, didn't notice the little upload-cloud icon at the bottom. File attached.
Message 9 of 11
davebYYPCU
The more you look, the easier it can be. (one sketch)
Takes some thinking to keep the ellipse constrained.  Adding geometry to the ellipse would sometimes unconstrain it.
I broke the Ellipse and made the larger side construction.
Might help...
Message 10 of 11
TheCADWhisperer
@GeoffKornfeld
(view in My Videos)
Message 11 of 11
GeoffKornfeld
Thank you all for the responses! I've been super busy, so I apologize for my lack of engagement with my own thread. 😝
