hollowing a complex STL
hello
so recently i got a helmet in a stl file but it has a heap of faces and is solid. the main problem is that when i go to hollow it with the shell tool, fusion crashes on me
here is the link if you wanna try to solve it
http://www.mediafire.com/file/v6fkzmtw9qszgxc/ODST_HELMET_main_v5.f3d.zip/file
thanks, father
lichtzeichenanlage
- Use Autodesk MeshMixer
- Use Microsoft 3D Builder
- I'm not sure, but perhaps a Slicer can do the job, too. I would check Prusa Slicer and slice it for a resin print.
Yes I got it
thanks a lot 🙂
