Explode Text
Explode Text
manolo.dev
Explode Text
manolo.dev
I am trying to explode Futura Condensed Bold, I saw some threads in this forum from 2015 or earlier, I wonder if Autodesk is still trying to fix this? maybe after 4 years they already fixed but I can not find a way to explode text. Tried in Youtube as well, same answers. Any help is more than welcome.
MichaelT_123
Hi Mr ManoloDev,
There might be nothing to fix. Some fonts come with limited usage licenses, and the level of restrictions can vary between devices ( operating systems). Apple OS seems to be a more restrictive environment.
Consider checking the font embeddability property (File Property/ Details Tab)
Regards
MichaelT
PS. Perhaps TF360 could filter the restricted fonts out?
MichaelT
manolo.dev
Understood, so what should I do in my case of futura condensed, I found the font in the internet for free, I need exact this one, I can buy if is the case. What should you do in your experience for this font to be available in fusion 360?
You said check, but check for what?
Thanks for the reply
MichaelT_123
Hi Mr ManoloDev,
You can do practically nothing other than manually retrace glyphs images of your interests. I would not recommend it though.
Just change your esthetics and find another one, look at it for a while, and you will like it. It is like with the marriage.
Regards
MichaelT
MichaelT
manolo.dev
Understood, but the font name is specific for what I need, is there a walkaround to have this one specifically?
Cheers,
g-andresen
I tested it and was able to create the font in V-Carve pro and export it as SVG.
Maybe you have a possibility to do it this way. If it is only one time and not too extensive, I would send you the text as SVG.
Inform me then by PM.
günther
manolo.dev
Thanks for your time, I will try...
