Message 1 of 9
The construct in the attachment is simple enough--I generate a ring from a sketch with a circular rotation extrusion. Then I place a hole on the ring and finally duplicate it 5 more times about the ring. I use Create:Pattern for this.
In order to do this, I select the original hole as my fist Pattern Object--then I select the center of the ring as my axis. The latter is somewhat nebulous in the doc but an axis appears when I place my cursor on the ring and I use this.
The result can be seen- the holes are not centered but offset--Only thing I could imagine is the axis that is generated it "off". I played with construction for this but no better results.
Fritz
