Hole type Pattern not centering properly
fsonnichsen
Message 1 of 9
fsonnichsen
The construct in the attachment is simple enough--I generate a ring from a sketch with a circular rotation extrusion. Then I place a hole on the ring and finally duplicate it 5 more times about the ring. I use Create:Pattern for this.
 In order to do this, I select the original hole as my fist Pattern Object--then I select the center of the ring as my axis. The latter is somewhat nebulous in the doc but an axis appears when I place my cursor on the ring and I use this.
The result can be seen- the holes are not centered but offset--Only thing I could imagine is the axis that is generated it "off".  I played with construction for this but no better results.
Fritz
Replies (8)
Message 2 of 9
etfrench
The file doesn't seem to match the description: No holes, no patterns, no rings.
ETFrench
Message 3 of 9
fsonnichsen
Good Grief!  That's what happens when I stay up too late. Sorry for the confusion. I have no attached the proper f3d.
thanks
fritz
Message 4 of 9
HughesTooling
You moved the component then used the document origin as the pattern axis.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 9
g-andresen
no wonder if you use a wrong axis
günther
Message 6 of 9
fsonnichsen
OK--I think i had selected a sketch:construction axis. When I tilted the diagram a bit I could see another set of axes which-I believe- coincide with the center of the circle. (no doc on this). Selecting this produces the result so apparently the two axis do not naturally align.
Thanks!
fs
Message 7 of 9
HughesTooling
Thanks!
fs
You moved the component (maybe just dragged by mistake) so its origin is no longer the same a the document origin. You've used a capture position to save the moved position. Some advice for when you get to making assemblies. Do not use Move and capture position, always use a joint. Actually if you're using Move on bodies or components then you're probably doing it wrong.
Mark Hughes
Message 8 of 9
HughesTooling
Also it looks like when you created the pattern you didn't have the component active, you had the main top level active. When you create a pattern the active component's origin is made visible. If you'd had the Ring component active its origin would have been visible.
Mark
Mark Hughes
Message 9 of 9
fsonnichsen
OK-There is a whole issue around move, capture, and the whole issue of relative positioning of parts that is not clear to me. Both the doc and a few books I have seem to like to "gloss" over this but I think it is one of the more important fundamentals of the project.
   In general, the "capture" seems to be asked for when I do a lot of procedures. Also, I am thinking that they can be removed from the timeline without problems later. But certainly not clear.
Thanks for the additional pointers Mark!-
Fritz
