Hole tool NPT thread missing modeled option
fungus_among_us
Message 1 of 42
fungus_among_us
Hi all,
I have a part that needs two 1/2"NPT threads, and it will be printed on an SLA printer. The thread tool has a "modeled" option which works, but I do not see a "modeled" option for the hole tool when "thread" is selected. I'm not using the thread tool because NPT is _still_ not available there.
The browser "modeled threads" option is enabled.
Thanks for any help!
Replies (41)
Message 21 of 42
ditcheldiablo
Community Visitor
Community Visitor
i eneded up creating a another body on the panels with the threaded holes that have tapered hole and combining them to create a kind of npt thread.
 I was mostly posting because I want auto desk to make it an option so I check a box instead of an additional hour plus of work. or having to hand tap a 3d print
Message 22 of 42
boasqualitycustoms
I used a stock fitting drawing of a 1" npt from McMaster and it STILL doesn't output an effin taper on the thread. Garbage.
Message 23 of 42
youngro8
its 2023 and is it true we still cant make NPT threads?
Message 24 of 42
Daveb1972
Observer
Observer
You can. They are there for holes.
Message 25 of 42
boasqualitycustoms
I ended up getting it to work by modeling a simple tapered cylinder, using the thread tool path and defining the pitch and pitch diameter offset. It took more than enough fking around, but it did work. It was the external 1" npt, the part doesn't look great, in the sense that I can see it's going point to point rather than an arc so it shows in the light at the right angle, bit the parts seal like they're supposed to. Probably helps that the part is HDPE.
Message 26 of 42
youngro8
I tried hole mode but the option for NPT still did not show as one of the options. However I just checked again and it is showing now, i'm not sure if it was the location of the hole before or something else.
Message 27 of 42
boasqualitycustoms
That explains why I assumed you must have been talking about the external npt because there is the internal npt LOL.
Message 28 of 42
dstillson
Observer
Observer
It is available as a drawing feature and will not model for printing!!!!
Message 29 of 42
GeekFieldGuide
This is something that is sorely lacking. Still.
Message 30 of 42
RogerInHawaii
It is now October, 2023 and STILL no NPT thread support.!!
Message 31 of 42
alisureyyatorun
Now we are in December 2023 and still no luck.
Message 32 of 42
laird2205
Observer
Observer
As far as I can see, it still doesn't work. Thread modeling is set to default and the NPT thread done in the hole command won't show in the stl file.
Message 33 of 42
kypper
Community Visitor
Community Visitor
Thanks for the update, I was researching how to create NPT threads but now I see that Fusion 360 still cannot do it.
Message 34 of 42
laird2205
Observer
Observer
I did successfully do it by inserting a McMaster-Carr pipe fitting to make the thread. Very poor that they don’t fix it.
Message 35 of 42
murray_rc
Community Visitor
Community Visitor
Wow. I need a ntp thread as well. No model check box
Message 36 of 42
laneveach
Community Visitor
Community Visitor
Just discovered this issue. Still no fix?
Message 37 of 42
RogerInHawaii
I think I noticed a new YouTube video recently about custom threading now built in to Fusion 360. I can't find it now, but did come across this fairly recent video that might help.
https://www.youtube.com/watch?v=fvpaUVE0GIc
also this:
Design & 3D Print Triple-Start Threads using Fusion360 (youtube.com)
Message 38 of 42
darinhouston
crazy - I need some sprinkler parts and they're all NPT.
Message 39 of 42
Warmingup1953
Yes...They're simply messing with us...Some sort of crazy software engineer reverse Easter Egg kind of thing...
Message 40 of 42
brian.davidson43788
im seeing the option for NPT holes if you select 'taper tapped' and i can do everything id expect to do right up until i would select the 'modeled' option but it is missing.  surely this is what is being discussed here but i haven't seen a screen shot so i took one to share if this helps with the confusion.  im still working on a solution myself because it makes no sense to have the visual option and not the ability to model it or am i missing something?
