Hole tool NPT thread missing modeled option
fungus_among_us
Message 1 of 42
fungus_among_us
Hi all,
I have a part that needs two 1/2"NPT threads, and it will be printed on an SLA printer. The thread tool has a "modeled" option which works, but I do not see a "modeled" option for the hole tool when "thread" is selected. I'm not using the thread tool because NPT is _still_ not available there.
The browser "modeled threads" option is enabled.
Thanks for any help!
Replies (41)
Message 2 of 42
harry.doldersum
To answer 1 of your remarks: the hole function can provide you with a modeled tapped hole - however, to reach the checkmark for the option "Modeled" you may need to scroll the option box down, though... it's at the bottom. On my screen, it's not visible either - I also need to scroll to reach it. Maybe you missed that?
As for the missing NPT option: that's indeed dearly missed,
Hope this helps a bit. 🙂
Message 3 of 42
HughesTooling
Fusion can not generate tapered threads at all unless you want to model them.
What you could try is use McMaster Carr from the insert menu and download a part with a thread in it or use a plug. Using a plug will not really give the correct thread form but might do.
I found this cap, you should be able to combine it with your part.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 42
harry.doldersum
I've struggled with NPT threads in the past too - but your suggestion to use a standard plug as cutting tool is a most welcome work-around: it gets the job done. Much appreciated! 🙂
Message 5 of 42
fungus_among_us
Hi Harry,
I do not see such an option within my settings:
If it's not too much trouble on your end, could you screenshot what you see?
HughesTooling, I have used a plug as a negative in the past, but you're at the mercy of the manufacturer at that point... I'd prefer to model them manually before that. These SLA printers are surprisingly precise, so you can get usable threads out of them.
EDIT: Also, the modeling option within the hole tool should be superseded by the browser toggle, no?
Message 6 of 42
HughesTooling
The browser option is just a quick way to toggle all threads in the design as in a big design you would not want modeled threads while working on the design. You can still override the document setting for individual hole features.
Also, as I said Fusion does not create modeled taper threads from the hole or thread tool.
Mark
Mark Hughes
Message 7 of 42
harry.doldersum
No, you're completely right: the checkmark isn't showing for NPT threads, that option is not available. As I said, NPT is dearly missed. The modeling option is only showing for parallel thread profiles: should you select an ISO metric one, the checkmark will pop into the dialog at the bottom
Modeled checkmark.JPG.
Message 8 of 42
fungus_among_us
Not trying to be contrary, but I asked further because you stated that Fusion could not create tapered threads at all, which it can through its thread tool (only DIN, ISO & BSP unfortunately).
@harry.doldersum, thank you for taking the time to do a sanity check! I see now what you were speaking of. Looks like I'll be modeling them for the time being.
Thank you both for the help.
Message 9 of 42
fungus_among_us
Which is apparently confusion on my part, as none of those are tapered. You are correct that the thread tool cannot generate ANY tapered threads.
Thank you.
Message 10 of 42
HughesTooling
Not sure what you mean, I was stating Fusion can't generate modeled taper threads (Thread and Hole feature), as far as I can see it can't. From what I can see the thread feature can't produce any tapered threads, modeled or cosmetic. The hole feature can produce tapered cosmetic threads but that's it. Think the tapered hole created by the hole tool is the correct core size for the thread and can be used in the manufacture workspace as a reference for thread milling.
Mark
Mark Hughes
Message 11 of 42
HughesTooling
Don't know if you've thought of this. If you're modeling the thread yourself you could create a plug in a separate design then insert it and combine cut so you don't need to model every time.
Mark
Mark Hughes
Message 12 of 42
@HughesTooling This worked perfectly for me. Had to clean up the plug dimensions to match my model, but the NPT threads worked.
Message 13 of 42
matthew.sanders545
Observer
Observer
The modeled Feature is no longer an option. Has fusion 360 really made this process that hard to implement.  Do we really need to select "modeled"  for it to actually work the way we want??!
Message 14 of 42
Daveb1972
Observer
Observer
I don't understand why NPT threading isn't available. This feature is in many cad programs, after being told this fusion would replace those for us, we seem to be lacking in capability......
Message 15 of 42
dbogroupr
I want to keep this topic alive as ongoing feedback to Autodesk, yes it is too bad we can't automatically create NPT threads in fusion by using threading functions that work so great with other threads.
Message 16 of 42
dewaine50
Bumping this thread. It's been years. Still no NPT option. For something so small, that every other CAD software has, this is ridiculous.
Message 17 of 42
dbogroupr
Agree, cutting and gluing with pieces of McMaster-Carr fittings is not an elegant practice, while modeling the taper and the spiral is a huge drag on the human and a perfect task for a computer.
Message 18 of 42
wilczakd
Observer
Observer
Bumping. It's been years. Still no NPT option! Pretty sad to not have such a common feature. I don't know if it's laziness driving no change or it's a fundamental flaw in their software. Either way it's not a good look for the fusion 360 team.
Message 19 of 42
ditcheldiablo
Community Visitor
Community Visitor
I was trying to model a npt thread this week yo 3d print a prototype but as gheres no feTure to model a thread I've been having to tap my 3d prints. What's not really what I want ho be doing as it adds another process to my prototyping
Message 20 of 42
dbogroupr
You could use parts of McMaster-Carr fitting step file, as a tool or a
piece of your model. This will not give you a correct model of the thread
but is probably close enough for 3d printed parts.
