Hole Parameter Changes Not Flowing to All Hole Specifications
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there:
I am a newbie here. I am having trouble with the hole command. I recently was working on F360 base design for a small steam engine. I made a group of four ("4") counterbored holes. After making the holes, I went to the F360>>Modify>>Change Parameters. At Change Parameters, I defined the hole diameter, hole depth, counter-bore diameter and counter-bore depth for what is called hole 3. However, when I went to hole3 icon (lower left hand corner) and then clocked on "Edit Feature", I found that the hole diameter is listed as the defined term (namely, Hole3Depth). However, the hole depth ("i"), counter-bore diameter ("ii") and counter-bore ("iii") still show the old numbers. As far as I know, "i", "ii" and "iii" should instead show defined terms (namely, Hole3Diameter, CB3Depth, and CB3Diameter.
PS I am running this on Lenovo laptop, Ideapad 360 with Windows 10 (64 bit). My F360 version is 2.0.4854
Except for Hole3Depth, it turns out that the defined terms are not saving for hole #3 in Change Parameters. They saved for a minute but I just went back and the parameters are not defined ones. Additionally, I am unable to change the parameters for hole #3 using the "Edit Feature" function for these set of holes. Please provide me some suggestions on how to fix this.
