Hobbyist Trying to Convert STL to Solid
efaden
efaden
Any chance someone could help convert this STL to a solid?  Tried doing it without prismatic and get most of the way, but the filets/chamfers are causing issues and that's one of the things I need to edit.  Just a hobbyist here with very limited fusion experience.  Thanks in advance.
CGBenner
@efaden
Welcome to the forums!  I moved your post here for better findability.  Good luck.
Chris Benner
g-andresen
project the body  into sketch, remove the arcs and reconstruct the sketch.
(view in My Videos)
günther
efaden
Awesome!  Thanks.  Then just use filets to create the ramps?
g-andresen
No fillets!  >  Chamfers!
(view in My Videos)
günther
CGBenner
@efaden
Hi, Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
