Failed to get owner/target occurence transform
maxhheaven
maxhheaven
I changed a dimension (red circles and arrow in picture) which has no bearing on the location of the relevant faces and holes that the  "Failed to get owner/target occurence transform" error shows up as, For the sketch I have tried to redefine the sketch (didn't work) and tried to use the manage lost projection tool which also didn't work. None of the relevant geometry has changed position as it was very constrained and im very unsure as to why this has occured and what I can do to fix it.
TheCADWhisperer
@maxhheaven
Drag the playhead marker in the Timeline back to the first sketch.
Ctrl b
Any unresolved issues highlighted on the Timeline?
Yes - resolve the issue.
No - step forward one step on the Timeline and repeat.
Loop through diagnosis/treatment till the end.
maxhheaven
Ctrl b seems to have worked! I genuinely have no clue what that did and why that fixed everything but thank you a lot!!
TheCADWhisperer
@maxhheaven
You haven't resolved the issues that are clearly highlighted in the Timeline.
For example, this Hole is supposed to cut through multiple bodies.
I also noticed that most of your sketches are not fully defined, and you have a lot of duplicated dimensions.
maxhheaven
My bad, I uploaded the file before I fixed the issues, sorry that is confusing. And yeah duplicated dimensions is something I’m trying to improve as well as fully defined sketches
