Hexagons following circular path issue
richard552CX
Message 2 of 25
richard552CX
Hi, I'm having trouble removing the distortion where the hexagons meet. Does anybody have any smart ideas as to how I could fix this issue. I've tried tracing the hexagon and leaving one side off and following the path that way but I couldn't get it to work. : (
Replies (24)
Message 1 of 25
richard552CX
Message 3 of 25
johnswetz1982
Is this a circular path or a a tapered circular path? Attaching the file would help. File>Export>*.f3d and attach.
Message 4 of 25
MichaelT_123
Hi Mr Ritchard552CX,
The Earth is not flat and The Circle is not straight.
Create the 'distorted' hexagon first (utilizing radial segments of The Circle) and then pattern the shape.
Geometry, geometry, geometry,....|:)
Regards
MichaelT
MichaelT
Message 5 of 25
davebYYPCU
Your distortion is not distortion, it's expected behaviour when using a true Hexagon.
For a circular pattern you have to distort a true hexagon to a distorted one.
Might help....
Message 6 of 25
TrippyLighting
Can you share your model ? (export as .f3d and attach to next post)
Message 7 of 25
Marco.Takx
Hi @richard552CX,
This question here is a Design question.
But you posted on the manufacturing forum.
Please place these kinds of questions on the Fusion-360-design-validate & Documentation forum.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 8 of 25
daniel_lyall
@Marco.Takx  You can ask DM to move it.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 9 of 25
seth.madore
@daniel_lyall  @Marco.Takx  I too can move threads around, so if you see something in the wrong place, just ping me
Seth Madore
Message 10 of 25
TrippyLighting
@richard552CX You appear to have posted this in two different sections of the forum. I ma not sure this was intentional, buts case it was, please avoid double posting. Thanks in advance!
Here's the thread on Design forum
Message 11 of 25
TrippyLighting
I am assuming this is what you're after:
Message 12 of 25
sjeffff
Based on your image I assume you have a central point on which you try to create a hexagonal shape around it.
I recreated a simpler variant of this which can be viewed here:
https://a360.co/2YMhEym
The source of the problem is related to the 6 sided shape. I do not know if it is possible to get the desired effect you want by using  some mathematical formula to calculate the dimensions of the circle and the hexagon. In order to calculate how much fit on a circle. I don't think so, but would like to be proven wrong 🙂
Message 13 of 25
seth.madore
Sorry @TrippyLighting , he started a thread in Manufacture and I just moved it over here this morning. I can flag one of the threads to be closed
Seth Madore
Message 14 of 25
chrisplyler
Well, the problem is simple geometry. A true hexagon has parallel opposite sides. You want to have a pattern of them radially. So the sides of one aren't going to be parallel to the sides of the one beside it.
You're going to have to construct a "distorted" hex. I've used 10-deg of arc to construct mine on, so that I can evenly put 36 instances around the circle and their sides will overlap correctly.
Message 15 of 25
chrisplyler
I think I've proven you wrong in my previous post. You can use it for ANY shape. It's simple. Divide the number of instance you would like to have into 360-deg, and make the width of your shape that many degrees wide.
If you want hard values, of course, you're going to have to know the radius of the circle and plug that into the equation as well. But since we can design graphically in a sketch, we can set it up so we don't need to do that math. We can instead just lay out our desired slice of the pie and construct our shape within it. If you constrain everything properly, it will even adjust with a diameter change of the circle.
It works if you change the degrees of the pie slice also, although of course you will have to edit the quantity of instance in the pattern to match.
Screencast will be displayed here after you click Post.
3145d348-1fef-413c-a503-26b7b3eb4748
https://knowledge.autodesk.com/community/screencast/3145d348-1fef-413c-a503-26b7b3eb4748
Message 16 of 25
TrippyLighting
I though had already answered that in my post and the  model provided above.
Message 17 of 25
sjeffff
Thanks, do have to say that it took me quite some tries to figure it all out. The trick is to use that 10 degrees mark from the central circle. Rather than just drawing a hexagon via a sketch tool, and adjusting its angles. After further study of you image I noticed that you did not used this polygon tool at all, but just used a circle. Thanks for proving me wrong ;-). I didn't know that you can still call a 6 sided polygon a hexagon. Without all 6 sides being equal in length.
Message 18 of 25
TrippyLighting
You can! The case with 6 sides of equal length is simply a regular hexagon
Message 19 of 25
chrisplyler
Six side of equal length at equal angles to each other. It's infinitely possible to have six sides of equal length without the figure being a regular hexagon.
@sjeffff  I did use a regular hexagon in my sketch, to help me construct the distorted one. I only used the circle to make it easier to define the circumscribed polygon. The circle isn't necessary, just made it easier for me. You can see it in blue. For the distorted one, I used the same upper and lower points, and made the upper two lines and lower two lines colinear with the regular one's lines, but with outside end points falling on the 10-deg pie slice sides.
There is any number of ways you might construct a distorted figure. That's just how I chose to do it.
Message 20 of 25
TrippyLighting
According to my "sources" a regular hexagon also needs equal interior angles 😉
