Help
Help
Message 1 of 31
Help
I can't split this along where i have marked, on the left the plane wont divide when i sketch onto it, please help it's driving me nuts.
Replies (30)
Message 21 of 31
Its a bad attempt but here
Message 22 of 31
daniel_lyall
Is it this that you wont I moved them apart for the visual
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 23 of 31
Yes!!!!!
Message 24 of 31
davebYYPCU
Your sketches of that profile do not intersect with end points at the moment, zoom right in to the intersections and you will see they do not connect.
A cutter that shape, might be impossible with your file in it's current state.  The cutting profile is normally a line or series of lines that you could extrude as a single selection,
In the Patch modelling area, your file does not allow Patches to be created, so I think you are stuck, without some sort of chipping away with lots of small separate cuts.  Make the shape with chamfers and spitting tools, and then combine the other end to it.
Best of luck....
Message 25 of 31
davebYYPCU
You had me fooled...
Message 26 of 31
I only started using CAD last night so excuse my slowness to understanding it. none the less I will try to find a way of doing this I think i see what I need to do now
Message 27 of 31
daniel_lyall
@davebYYPCU projecting the sketch onto a offset plane then redrawing it so it's useable then useing split body does the trick.
@Anonymous The model of yours needs redone it's messed up, it is easyer to just redo it.
All you need to do is project the end profile onto a plane taken from the origin then copy the sketch then start a new model create a component start a sketch in that component then past the sketch in Aline it to the origin, then you can extrude it.
Then do a offset plane off the origin above the model draw the splitting sketch on it, then go into the patch environment and split body.
I am doing an example now
Daniel Lyall
The Big Boss
Mach3 User
Message 28 of 31
daniel_lyall
Example attached
Daniel Lyall
The Big Boss
Mach3 User
Message 29 of 31
daniel_lyall
@Anonymous lead with you are brand new to fusion you wont get any judgement on this forum If we know you are brand new to fusion it helps a lot, you will get your hand held.
Daniel Lyall
The Big Boss
Mach3 User
Message 30 of 31
davebYYPCU
Don't worry bout me, I was trying to make sense of 15 sketch lines to make a cutter with patches, when your done deal popped up.
Message 31 of 31
daniel_lyall
I learnt that one from you
Daniel Lyall
The Big Boss
Mach3 User
