Help
Help
Message 1 of 31
Help
I can't split this along where i have marked, on the left the plane wont divide when i sketch onto it, please help it's driving me nuts.
Replies (30)
Message 2 of 31
TrippyLighting
What sort of solid geometry are you expecting to receive from that sketches outline ?
You can go into patch mode, unstitch and split the surface bodies individually.
Message 3 of 31
Okay I'll try to follow what you said, sorry  I'm new to CAD
Message 4 of 31
No I'm still having trouble with the surface on the left side of the model, it won't split/separate.
Message 5 of 31
I think it's because i made the model weirdly, I'll just try re doing the whole thing
Message 6 of 31
And that didn't work and I've just wasted many hours 😕
Message 7 of 31
daniel_lyall
Can you post the model file you are working on, Go to File -> Export and save as a .F3D Archive File and attach it to your next post
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 8 of 31
Sure, I also attached at the top I think
Message 9 of 31
davebYYPCU
As @TrippyLighting said, it is hard to work out just what bits are needed for the trim tool,
the plane at the end of the model is not apparently aligned through the body,
Working from file from first post, and yes a wonky set of manouvres so far, why is there one line per sketch near the end of the timeline?
Can you add more detail for what you want?
Message 10 of 31
Basically I just want the sketched outline that I've done to split the 3D model into two parts
Message 11 of 31
davebYYPCU
Good luck with that,
there are as many as 8 possible plenes involved in the sectioning lines,
Message 12 of 31
I don't understand why it doesn't let me do it easily
Message 13 of 31
It's just that one plane on the left that wont split
Message 14 of 31
daniel_lyall
What sketch number is the one to use for splinting the model there are a lot of sketches on the left side and only sketch planes no planes
Daniel Lyall
The Big Boss
Mach3 User
Message 15 of 31
I don't fully understand, if you could split the model as intended and attached it to this post I'd be very grateful
Message 16 of 31
davebYYPCU
Your original file does not have any Construction Planes, the Origin planes are on the top corner.
The article that looks like a plane on the Origin is the profile from the original plate you made, before the chamfers.
There are 15 sketches on the end of the time line, each has one line in it.
We haven't worked out where to split the model yet.
Message 17 of 31
😕 yeah I still don't know how to do it...
Message 18 of 31
daniel_lyall
@Anonymous Take a screen grab of what you wont and open it in paint and draw an Arrow where you wont it split
Daniel Lyall
The Big Boss
Mach3 User
Message 19 of 31
daniel_lyall
@jeff_strater All your's
Daniel Lyall
The Big Boss
Mach3 User
Message 20 of 31
I've gone round all the sketches and split them all, how do i now split the whole model
