Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Help with step file editing
6 REPLIES 6
cyucelEJ2QP
408 Views, 6 Replies
Hello all,
I am trying to edit this step file, to make the radius of the circular region larger, at a specified size.
After trying and failing for a while tried to ask 🙂
Rectangular mount section has to stay at the same size.
I really appreciate if one of you can spare few mind to explain (or better screen capture) how this can be done, of course if it is possible at all.
Best,
Ali
Tags (1)
6 REPLIES 6
wersy
in reply to: cyucelEJ2QP
If you delete all fillets one by one...
...you get this.
cyucelEJ2QP
@wersy , thank you, everything looks much simpler now. How can I increase the radius of the cylinder ? I am trying press pull but keep ending up with an awkward structure. I am sorry, I know I am asking something perhaps too basic.
davebYYPCU
Sketch a 2 point circle, from top dead centre or some other reference, with the circle diameter dimensioned.
Remove the original, and Extrude join the new one.
Might help....
wersy
I would do it with a sketch and extrude
cyucelEJ2QP
Got it, basically I delete the old circle an sketch / extrude new.
wersy
@cyucelEJ2QP
If you find my answer solved your question, please select the Accept Solution icon
Technology Administrators
