Hello all,
I am trying to edit this step file, to make the radius of the circular region larger, at a specified size.
After trying and failing for a while tried to ask 🙂
Rectangular mount section has to stay at the same size.
I really appreciate if one of you can spare few mind to explain (or better screen capture) how this can be done, of course if it is possible at all.
Best,
Ali
Solved by wersy. Go to Solution.
Sketch a 2 point circle, from top dead centre or some other reference, with the circle diameter dimensioned.
Remove the original, and Extrude join the new one.
Might help....
If you find my answer solved your question, please select the Accept Solution icon
