Help with simple simulation question - constraints
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I am trying to learn Fusion 360 simulation and have a quick question about constraints.
I have a simple 2" thick aluminum plate that I will be hoisting with eye bolts threaded through 4 holes in the corners. The plate will hold an object that weighs 2.308e4 (ouncemass, according to Fusion) or 1442 lbs.
To see if the aluminum plate will handle that amount of weight, I take it to the simulation environment and remove the eyebolts (they are rated for 5000 lbs a piece on McMaster Carr). I apply 11601 lbf of vertical force to each of the cylindrical holes in the plate ( [1442 lbs * 32.17 ft/s^2] / 4).
I guess I technically have two questions:
- Are the cylindrical holes the proper place to apply the force?
- Which face of the plate (top or bottom) should be constrained? I think it should be the top face (which is how I have it constrained in the above picture) , as that is the one that is having pressure applied to it from the object that's resting on it, but I am unsure. I am unclear on how exactly the constraints work.
Any advice would be greatly appreciated. Thanks a lot!
