Well title says it all
I have tried several ways to construct an offset plane but it always its up so that the z axis points the wrong way so the hole function will not cut into the body.
Attached is file component; roller latch:1 Sketch; Slot Plane; Plane 7
Solved by jhackney1972. Go to Solution.
Got it
I set the plane up where i wanted it which happens to be slightly inside the body....
I kept trying to cut the hole first. It always wanted to go the wrong way.
But if I extruded a cut so that the top surface of the hole was exposed then viola the hole cut the right way.
Sorry to bother you.
I know you have solved your issue but I wanted to take the opportunity to give you a new method of doing this with the creation of a Base Feature, in this case a construction plane you can rotate. Take a look at the video.
John Hackney, Retired
