Help with resolution when moving an object's face.
jsrfo
jsrfo
I am very new here at Fusion 360, and I am having trouble moving a face on a STEP file. It seems that I can only move the face in increments of 0.1" increments. I did at one point move in 0.05" increments, but I can't seem to get back there. But 0.1" or 0.05" is still too coarse of a movement. I need to move the face with the red arrow pointed at it up 0.005", to widen the slot. Just can't get there, as the move command only  moves it up 0.1". Any help would be appreciated. Thanks.
jhackney1972
Please attach your model so the forum users can take a look at it for you.  If you do not know how, open the model in Fusion 360, select the File menu, then Export and save it to your hard drive.  Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
etfrench
Duplicate post.
ETFrench
jsrfo
I attached the one file. Hope it's what you need.
jhackney1972
I was the one you asked for the file.  @etfrench pointed out that this is a duplicate post, in message 3, and it has already been answered.  Please mark it as solved to remove it from the forum board.
