Help with patching bodies
jeffescott
Advisor Advisor
jeffescott
Not even sure this is the right work flow, but the result is almost there
Unfortunately I have created some gaps in the body
How do I best heal these gaps.
The gaps are in heel latch:1  and resulting from sketch 7 and extrude 10 and 11
jhackney1972
Heel latch is a solid body, it does not need Patching.  If you are speaking about the notches created by Extrude 11, then the solution is to extrude from the top surface instead of the profile.  Model is attached.
John Hackney, Retired
